transform from dxf to txt and back
Hello! Why, after translating points from dxf to txt using Cloud compare and importing them back into CAD, do the points have an offset? The accuracy of the coordinate output is set to 6 digits. In the screenshot, the red dots are the translated points.
- 1.jpg (45.11 KiB) Viewed 11478 times
Re: transform from dxf to txt and back
Hi, do you have an example DXF file (and the resulting TXT file maybe)?
