Assembling objects in CloudCompare
Guitar Quackery
Post by Guitar Quackery »
Hello all,
I just started using CloudCompare to view 3D scans of guitars and guitar parts.
I was hoping to be able to import separate guitar parts into a project and then move and rotate each guitar part separately so that I can assemble a guitar in 3D space.
Can this be done in CloudCompare?
Thanks.
Guitar Quackery
Re: Assembling objects in CloudCompare
Here is a screen shot of what I am trying to do.
There is a point could scan of a guitar and a scan of the guitar bridge (in the yellow box).
Screenshot 2025-04-15 at 10.45.32 PM.png (1010.75 KiB) Viewed 12117 times
Is it possible to move the bridge in the correct place on the guitar?
Thanks.
Well, yes, but mostly manually. Use the 'Edit > Translate/rotate' tool.
See https://www.cloudcompare.org/doc/wiki/i ... ation_Tool
I don't think registration/alignement tools will be very useful (apart maybe for the point pair picking tool... see https://www.cloudcompare.org/doc/wiki/i ... gistration)
Guitar Quackery
Thank you very much. This is in fact very helpful.
Zizelind
Post by Zizelind »
Yeah, I’ve done something similar with CloudCompare when working on scanned mechanical parts. You can definitely move and rotate separate pieces, but it’s a bit clunky. I had to import each part individually, then use the Translate/Rotate tool (it’s that little cube with arrows) to position everything. Just make sure you're selecting the right part in the DB Tree before adjusting it, took me a few tries to get used to that. It’s not the smoothest workflow, but it gets the job done.
