Hi there.
I am trying to find a quick way to compare the Z-values of my pointcloud with a txt-file with controll points.
I just want some sort of report that shows the difference in z between the controll points and pointcloud, optimally this should be done without the need for picking points.
Anyone know if this is possible in CLoud Compare?
Comparing Z-values in pointcloud with txt file
Re: Comparing Z-values in pointcloud with txt file
Well, you can do the first part relatively easily (with the C2C distances, and select the option to split the distance components along X, Y and Z). But there's nothing to automatically create a report in CC ;)
You would have at least to create a Python script or something equivalent....
Ok. Thanks for the respond😊
