ICP fine registration with georeferenced DXF
HüttenCrea
Post by HüttenCrea »
I would like to ask you if the ICP tool allows us to register point clouds after the point picking registration with the same DXF based geopoints (it has about only 50 points) I tried it but it doesn't work at all.Maybe the big difference between the point amounts is the problem?
Another problem I have with this issue is why I can't add more than 3 pairs of points in the manual registration.Always crashes the CC after the fourth pair of points.
Otherwise the error after the 3rd pair is only a few mm and scale is allowed as well.
Thanks.
HüttenCrea
HüttenCrea
Re: ICP fine registration with georeferenced DXF
Regarding the crash, which version are you using? I can't reproduce your bug with the latest version at least (2.14.alpha) but this part of the code has not been modified for quite some time. Don't hesitate to share your cloud with me ([email protected]) so that I can try to reproduce this on my side.
And regarding the use of ICP after using the align tool: it generally works (at least with dense clouds). The main conditions are:
- that the reference (static) cloud should be the most dense
- and with the largest coverage if possible. Else you have to play with the 'overlap' percentage so that CC is aware that not all the points of the to-be-aligned cloud should be used for alignment.
HüttenCrea
Dear Daniel, thank you for your last reply. Sorry, but I keep facing this problem, as detailed earlier in this topic. Crash always appears after selecting the 4th point pair. It's a bit tedious, unfortunately, as I want to align several points of our cloud (cloud recorded with Matterport Pro 3 high density mode) to our very precise points taken by LEICA Disto 3 D. Could you please check this attached file in your e-mail box.
The version I'm using is V 2.14 alpha. I understand that this is the latest, right?
Thanks in advance.
HüttenCrea
