when importing an SHP file into CC, the program crashes and closes if you try to consult the shift coordinates afterward (select SHP, Edit, Edit global shift and scale, crash !).
Has anyone else experienced this issue? Any solutions or workarounds would be appreciated.
Thank you!
SHP Shift Crash
SHP Shift Crash
- test.zip
- (3.24 KiB) Downloaded 1010 times
Re: SHP Shift Crash
mariolino,
Using your shapefile in CloudCompare_v2.11.1, I'm not getting a crash, or any problems at all. What version are you using?
Dave
Dave
Re: SHP Shift Crash
I can reproduce the issue with the latest 2.13.2 version!
I'll try to fix this ASAP...
Re: SHP Shift Crash
Ok, so this is a small bug that will be fixed in the next 2.14.alpha version.
Meanwhile, I believe you just need to select the vertices (the cloud below the polyline entity) and use 'Edit > Edit Global Shift and Scale' directly on this cloud). Normally it should work the same!
Re: SHP Shift Crash
Hi, Daniel
Thank you very much for the prompt update regarding the small bug ......
I truly appreciate the interim solution you provided. Selecting the vertices and using 'Edit > Edit Global Shift and Scale' directly on the cloud works perfectly.
Your support and quick response are greatly appreciated!
Best regards,
Mario
Best regards,
Mario
