Solution : Accent in the path file that caused the .yaml file to not save correctly.
When I try to load the classifier .txt file in the classification step, i get this error :
Failed to load the classifier file from (insert path to file here)
I really don't know that seems to be the problem here...
I am on windows and using the latest version of CloudCompare.
Here is what's inside the classifier .txt file generated after the training :
# 3DMASC classifier file
classifier: classifier.yaml
# Clouds (roles)
cloud: PC1
# Core points (classified role)
core_points: PC1
# Features
feature: ROUGH_SC0.1_PC1
feature: ROUGH_SC0.2_PC1
feature: ROUGH_SC0.75_PC1
feature: ROUGH_SC1_PC1
feature: ROUGH_SC2_PC1
feature: ROUGH_SC5_PC1
feature: ANISO_SC0.1_PC1
feature: ANISO_SC0.2_PC1
feature: ANISO_SC0.75_PC1
feature: ANISO_SC1_PC1
feature: ANISO_SC2_PC1
feature: ANISO_SC5_PC1
feature: SPHER_SC0.1_PC1
feature: SPHER_SC0.2_PC1
feature: SPHER_SC0.75_PC1
feature: SPHER_SC1_PC1
feature: SPHER_SC2_PC1
feature: SPHER_SC5_PC1
feature: LINEA_SC0.1_PC1
feature: LINEA_SC0.2_PC1
feature: LINEA_SC0.75_PC1
feature: LINEA_SC1_PC1
feature: LINEA_SC2_PC1
feature: LINEA_SC5_PC1
feature: PLANA_SC0.1_PC1
feature: PLANA_SC0.2_PC1
feature: PLANA_SC0.75_PC1
feature: PLANA_SC1_PC1
feature: PLANA_SC2_PC1
feature: PLANA_SC5_PC1
feature: CURV_SC0.1_PC1
feature: CURV_SC0.2_PC1
feature: CURV_SC0.75_PC1
feature: CURV_SC1_PC1
feature: CURV_SC2_PC1
feature: CURV_SC5_PC1
feature: Zmin_SC0.1_PC1
feature: Zmin_SC0.2_PC1
feature: Zmin_SC0.75_PC1
feature: Zmin_SC1_PC1
feature: Zmin_SC2_PC1
feature: Zmin_SC5_PC1
feature: R_SC0_PC1
feature: G_SC0_PC1
feature: B_SC0_PC1
Still Not able to load claissifier (SOLVED)
Re: Still Not able to load claissifier
You have no 'classifier.yaml' file associated with the file 'classifier.txt'? It should be in the same repository.
Yes, exactly, no .yaml file is in the directory !
Re: Still Not able to load claissifier (SOLVED)
[SOLVED]
The error came from the directory in which the classifier was saved. The path to this directory included an accent.
[SOLUTION]
Remove any accent from the path.
[SOLUTION]
