Can't load OBJ
jguinet
Can't load OBJ
Post by jguinet »
I have compiled and installed CC on liunx arch with Cmake (using master version), but i can't open OBJ files (my OBJ are OK I had tried in the past with an older cloudcompare version), please see the attached pictures.
I have tried to check some CMake IO option without results.
Do you know if there is compilation option for this file
Jonathan
Re: Can't load OBJ
You have to enable the QCORE_IO_PLUGIN project (CMake option PLUGIN_IO_QCORE).
jguinet
Re: Can't load OBJ
Post by jguinet »
Thanks for your answer daniel, it seems to have no effect on results.
QCORE_IO_PLUGIN seems to be correctly compiled :
objdump -TC /softs/projets/outils_qi/simu3D/3rdparty/CloudCompare-master/bin/lib64/cloudcompare/plugins/libQCORE_IO_PLUGIN.so |grep ObjFilter
0000000000031640 g    DF .text  0000000000001bb6  Base        ObjFilter::saveToFile(ccHObject*, QString const&, FileIOFilter::SaveParameters const&)
000000000003ecf0  w   DF .text  00000000000000a9  Base        ObjFilter::~ObjFilter()
0000000000033200 g    DF .text  0000000000003e2c  Base        ObjFilter::loadFile(QString const&, ccHObject&, FileIOFilter::LoadParameters&)
0000000000276708  w   DO .data.rel.ro   0000000000000018  Base        typeinfo for ObjFilter
000000000003ec60  w   DF .text  000000000000008c  Base        ObjFilter::~ObjFilter()
00000000000311a0 g    DF .text  0000000000000491  Base        ObjFilter::ObjFilter()
0000000000277578  w   DO .data.rel.ro   0000000000000040  Base        vtable for ObjFilter
0000000000049300  w   DF .text  0000000000000011  Base        QtSharedPointer::ExternalRefCountWithCustomDeleter<ObjFilter, QtSharedPointer::NormalDeleter>::deleter(QtSharedPointer::ExternalRefCountData*)
0000000000031170 g    DF .text  0000000000000024  Base        ObjFilter::canSave(long, bool&, bool&) const
but i have not found any link to this libQCORE_IO_PLUGIN.so in CloudCompare bin
CMakeCache.tar
(36 KiB) Downloaded 542 times
Re: Can't load OBJ
Have you proprely 'INSTALLED' the solution? (make install)
jguinet
Re: Can't load OBJ
Post by jguinet »
Yes with user INSTALL_PREFIX (i have not root permission on this machine)
