command line, PREFIX options
Please add option for custom prefix, aswell as enable the auto prefix as it is now where it adds the commands that has gone trough, like PCV
Re: command line, PREFIX options
I added this to the TODO list (but you'll have to hope that a contributor is motivated by this feature request ;).
Isn't it solved by the -RENAME_ENTITIES command, which i implemented 2 weeks ago?
After loading the cloud(s) call the rename entities and then run the rest of your commands.
If it is not what you meant then i suppose we should get some clarification about how it should work.
