Dear Daniel,
I know that I can change the animation size through changing the 3D view size.
However, I found that 2700*1600 is the maximum size of my computer. (As the screenshot below)
Is it possible to increase the image size to 4K(3840*2160) when rendering?
Thank you so much!
Animation: Can I increase my image size?
- 截圖 2023-01-06 上午2.48.31.png (1.06 MiB) Viewed 10201 times
Re: Animation: Can I increase my image size?
With recent version of CC, you have a 'super resolution / zoom' combo box:
really appreciate your help!
the animation plugin is very nice, the option to export the trajectory to me does not work, is there a special procedure to utlize it ?
One more question is it possible to export the data of a camera in ascii format, so as to porter create many new ones outside cloudcompare and then import them ? This would help especially for trajectories and clouds made with MLS.
Mario
Mario
Good catch, this 'export trajectory option' was not implemented! (the checkbox was not supposed to be visible). I've fixed that (it will be available in the next 2.13.beta release).
And to answer your other question, sadly there's no ascii/text format to define a camera sensor supported by CloudCompare. Mostly because we don't know any. If some format exists, then we would be interested to know about it?
Or maybe use a simplified 'VRML' syntax ...
Viewpoint {
position 0 5 5
orientation 1 0 0 0.39
fieldOfView 0.39
description "Camera 1"
Viewpoint {
position 0 5 5
fieldOfView 0.39
The latest 2.13.beta version is now online.
