A 10 m long road section is attached. The distance values calculated using the M3C2 tool are contained in this cloud. I exported the same segment as a CSV file.
Is there a tool that can take average values in the longitudinal direction? I refer to the case where I draw a polyline in the direction of the profile and receive the average longitudinal values. thus I could use it to calculate the maximum and minimum distance values.
In the attached file, I've shown my demonstration as a yellow line.
Computing average values
Tariqullah
- 10m_segment.jpg (132.5 KiB) Viewed 5638 times
Tariqullah
Re: Computing average values
Thank you Daniel for your reply to my question.
How to get M3c2 as an elevation profile
How to compare m3c2 in several scenarios with reference Dense cloud as a height profile as an output file in an open source program?
