Why are surfaces created even where there is no point cloud?
ken@67
Post by ken@67 »
When I applied Poisson Surface Reconstruction, the surface are created even where there is no point.
The black area shows point clouds.
Why the surface converges to a rounded shape?
Could you recommend an article or where should I get the theoretical guide?
2022-02-01 203603.png (61.95 KiB) Viewed 1933 times
Re: Why are surfaces created even where there is no point cloud?
Yes, the Poisson Surface Reconstruction algorithm creates a closed and continuous surface by default.
But there's a way to clean that afterwards: see the documentation: https://www.cloudcompare.org/doc/wiki/i ... n_(plugin) (especially the "Using the output density" section).
