How to calculate 3D objects’ volume?
JamesGregory
Post by JamesGregory »
Hello to all! Would someone tell me how i can calculate the volume of 3D objects plz? Thanks a lot.
Re: How to calculate 3D objects’ volume?
really 3D or 2.5D?
Anyway, there are basically two options that may work for you:
- https://www.cloudcompare.org/doc/wiki/i ... ure_volume
- https://www.cloudcompare.org/doc/wiki/i ... .5D_Volume
DA523
Post by DA523 »
Sorry I deleted this post by mistake ...while posting a new one
how to recover it
DA523
Post by DA523 »
Lets speak about 2.5D volume (Tools >> VOLUME >>Compute 2.5D volume)
it is the most professional method to find volume between 2 points clouds and works fine on 2 points clouds or single cloud and plane (constant x,y, or z)
it is the same as finding the area under function curve by numerical integration
Care should be taken because , it can give bad volume in some situations because of :
- Convex hull area if interpolation is used
- Empty cells, if the less dense points cloud is used with leave it empty choice
- Big grid size (too many points fail in each cell)
- One points cloud has more than one layer in the same projection direction
For example, 2.5D volume can not work on this attached mesh
Attached 1 bin file
2.5D volume.zip
(2.14 KiB) Downloaded 312 times
