Editing a obj or point cloud for 2D
pecospete
Post by pecospete »
I am new to point clouds meshes and the like. I cam across this software when i was searching on how to convert a .obj to a point cloud.
I would like to be able to use data collected from matterport scans, both for 2D plans and to create 3d models. I am familiar with Creo, solidworks and Autocad.
I have successfully opened a obj but any the options to edit the mesh are greyed out?
Can someone give me any direction on where to look to learn more?
Thank you
Re: Editing a obj or point cloud for 2D
In CloudCompare, whenever you want to apply a tool, you have to select the entity(ies) to process first.
Then, for your particular need, you should use 'Edit > Mesh > Sample points'.
