Export Dip direction - Dip angle from planes
Re: Export Dip direction - Dip angle from planes
Not to my knowledge. The RansacSD plugin code may have changed since this post was written indeed...
WargodHernandez
Ransac will find the planes, CC can then do a bulk export like usual
I ran Ransac on a cloud I had got 176 planes returned, I selected the folder that Ransac creates with the result and used (Tools->Batch Export->Export Plane Info)
Here is the first two lines in the export csv
I'm not sure off hand but I think you can do this in command line as well.
Name;Width;Height;Cx;Cy;Cz;Nx;Ny;Nz;Dip;Dip dir;
Dip: 000 deg. - Dip direction: 086 deg.;142.058;202.617;-18.1547;168.354;253.823;-0.00497566;-0.000287712;-0.999988;0.285305;86.6906;
