I want write my first CloudCompare plugin.
How to open .fls file in plugin?
Open file in plugin
Re: Open file in plugin
If the FARO file is loaded as well as your plugin, you should be able to load the file with the static 'FileIOFilter::LoadFromFile' method (by default all plugins should have access to 'FileIOFilter.h').
Based on the extension, the 'LoadFromFile' method should use the FARO I/O filter to load the file. However, I'm not sure if the plugin (DLL) will share the same context as the application. Therefore we may need to add an accessor to the file I/O filter in ccMainAppInterface (the 'm_app' member of the plugin). I'll let you test the first solution and wait for your feedback.
CCNewbieL6
Hello everyone!
I want to open .txt files in my plugin , I try to write these codes:
AsciiFilter* loadf = new AsciiFilter();
AsciiFilter::LoadParameters loadp;
AsciiFilter::SaveParameters savep;
loadp.alwaysDisplayLoadDialog = true;
loadp.shiftHandlingMode = ccGlobalShiftManager::NO_DIALOG_AUTO_SHIFT;
loadp.autoComputeNormals = false;
loadp.parentWidget = this;
loadp.sessionStart = true;
savep.alwaysDisplaySaveDialog = false;
CC_FILE_ERROR err = CC_FERR_NO_ERROR;
QString txtfile="D:\HJ\test\airplane_0001.txt";
QString txt ="";
ccHObject* ent = loadf->LoadFromFile(txtfile, loadp, err, txt);
The plugin works correctly, but when run the code "ccHObject* ent = loadf->LoadFromFile(txtfile, loadp, err, txt);" , the plugin enter no response state.
And the whole Cloudcompare application terminated.
I think there is sonthing wrong in the loadParameters or CC_FILE_ERROR , but I could not find it.
What should I do ?
Thanks!
QString txt ="";
What should I do ?
Thanks!
Actually, you don't need to allocate the filter dynamically (you can keep it on the stack). And you shouldn't call the static 'LoadFile' method (which is actually a method of 'FileIOFilter', relying on registered filters). You should call AsciiFilter::loadFile directly.
AsciiFilter filter;
ccHObject container;
CC_FILE_ERROR error = filter.loadFile(filename, container, loadp);
if (error == CC_FILE_NO_ERROR)
//'container' should contain one cloud normally
CCNewbieL6
I have edited my code:
The error still exist.
These are screenshoot:
this is the plugin:
Then I click it. It will load a.txt file directly.
Click apply:
Then I Debug it via VS2017:
Debug shows that error occured in CCCorelib.dll (maybe where function loadFile() located in).
I think when executing the function loadFile(), memory leaked.
I cannot figure it out.
QString txtfile = "D:/HJ/test/airplane_0001.txt"; //file_path
//Parameters:
loadp.parentWidget = m_app->getMainWindow();
AsciiFilter loadf;
ccHObject ent;
m_app->dispToConsole("loadf start", ccMainAppInterface::STD_CONSOLE_MESSAGE);
CC_FILE_ERROR err = loadf.loadFile(txtfile, ent, loadp);//load the cloud, always crash here
m_app->dispToConsole("loadf over", ccMainAppInterface::STD_CONSOLE_MESSAGE);
if (err == CC_FILE_ERROR::CC_FERR_NO_ERROR) {
this is the plugin:
Click apply:
WargodHernandez
Can you please try this version
FileIOFilter::LoadParameters loadp;
CC_FILE_ERROR res;
ccHObject *loadedObj = FileIOFilter::LoadFromFile(fullPathToObject, loadp, res, AsciiFilter::GetFileFilter());
if (res == CC_FERR_NO_ERROR)
m_app->addToDB(loadedObj);
else
ccLog::Error(QString("Failed to load file: %1, Error # = %2").arg(fullPathToObject).arg(res));
CCNewbieL6
Thank you very much! You solved my poroblem!
