Command line to export
sechanbask
Post by sechanbask »
I would like to export e57 file to las
I have tried this :
cloudcompare.exe "d:\file.e57" -C_EXPORT_FMT LAS - d:\potree\
or
cloudcompare.exe "d:\file.e57" -C_EXPORT_FMT LAS - d:\potree\file.las
but I get the same errors :
Error
[Load] Can't guess file format: no file extension
OK
Error
[Load] File 'd:\potree\file.las' doesn't exist!
OK
Can you help me to fix my mistake, please ?
Re: Command line to export
Don't you miss the '-O' command? (before the filename).
And then, make sure your CloudCompare version supports the LAS format (it should have a QPDAL_IO_PLUGIN plugin).
