I am trying to compile CC, but getting the error (see error.png). See also Cmake1.png and Cmake2.png for more info.
I also did the following changes (see Cake3.png), but no success.
Error while Compiling CC
- cmake3.PNG (15.24 KiB) Viewed 9280 times
- error.PNG (105.33 KiB) Viewed 9295 times
- cmake2.PNG (61.35 KiB) Viewed 9295 times
- cmake1.PNG (79.35 KiB) Viewed 9295 times
Re: Error while Compiling CC
The Visual build console is generally more helpful in this case (well, maybe not in German :-p).
Is it an error with setLocale? The Qt command? In this case this might be because of the Qt version? Can you try with an older one? 5.9 or 5.10? (just in case)
No...
I tried older versions also. 5.14.....5.9. There is not so much info of error. I have only diese Screenshots.
German-English
Befehl-> Command
German-English
Befehl-> Command
Can you then post the contents of the 'output' console? Should appear during the compilation process (with a lot of text, compiled files, warnings, etc.)
I am getting this error.
Unable to start program..... access denied.
There is no exe file in the folder. I think there is something missing and cmake is not properly working. I can send you project file as zip, but how to upload it????
1>------ Rebuild All started: Project: ZERO_CHECK, Configuration: Debug x64 ------
1>Build started 16.02.2020 16:25:05.
1>Target InitializeBuildStatus:
1> Creating "x64\Debug\ZERO_CHECK\ZERO_CHECK.tlog\unsuccessfulbuild" because "AlwaysCreate" was specified.
1>Target CustomBuild:
1> Checking Build System
1>Target FinalizeBuildStatus:
1> Deleting file "x64\Debug\ZERO_CHECK\ZERO_CHECK.tlog\unsuccessfulbuild".
1> Touching "x64\Debug\ZERO_CHECK\ZERO_CHECK.tlog\ZERO_CHECK.lastbuildstate".
1>
1>Build succeeded.
1> 0 Warning(s)
1> 0 Error(s)
1>
1>Time Elapsed 00:00:00.37
2>------ Rebuild All started: Project: CC_CORE_LIB, Configuration: Debug x64 ------
3>------ Rebuild All started: Project: CC_FBO_LIB, Configuration: Debug x64 ------
4>------ Rebuild All started: Project: qcustomplot, Configuration: Debug x64 ------
5>------ Rebuild All started: Project: translations, Configuration: Debug x64 ------
2>Build started 16.02.2020 16:25:05.
3>Build started 16.02.2020 16:25:05.
4>Build started 16.02.2020 16:25:06.
2>Target ResolveProjectReferences:
4>Target ResolveProjectReferences:
3>Target ResolveProjectReferences:
4>Target InitializeBuildStatus:
4> Creating "qcustomplot.dir\Debug\qcustomplot.tlog\unsuccessfulbuild" because "AlwaysCreate" was specified.
4>Target PreBuildEvent:
4> Automatic MOC for target qcustomplot
2>Target InitializeBuildStatus:
2> Creating "CC_CORE_LIB.dir\Debug\CC_CORE_LIB.tlog\unsuccessfulbuild" because "AlwaysCreate" was specified.
2>Target PreBuildEvent:
2> Automatic MOC for target CC_CORE_LIB
3>Target InitializeBuildStatus:
3> Creating "CC_FBO_LIB.dir\Debug\CC_FBO_LIB.tlog\unsuccessfulbuild" because "AlwaysCreate" was specified.
3>Target PreBuildEvent:
3> Automatic MOC for target CC_FBO_LIB
4>Target CustomBuild:
4> Building Custom Rule D:/CloudCompare/CloudCompare/libs/qcustomplot/CMakeLists.txt
3>Target CustomBuild:
3> Building Custom Rule D:/CloudCompare/CloudCompare/libs/CCFbo/CMakeLists.txt
2>Target CustomBuild:
2> Building Custom Rule D:/CloudCompare/CloudCompare/CC/CMakeLists.txt
5>Build started 16.02.2020 16:25:09.
2>Target ClCompile:
2> mocs_compilation.cpp
2> AutoSegmentationTools.cpp
4>Target ClCompile:
4> mocs_compilation.cpp
2> BoundingBox.cpp
2> CCMiscTools.cpp
2> CCShareable.cpp
2> ChamferDistanceTransform.cpp
2> CloudSamplingTools.cpp
4> qcustomplot.cpp
2> Delaunay2dMesh.cpp
2> DgmOctree.cpp
2> DgmOctreeReferenceCloud.cpp
2> DistanceComputationTools.cpp
5>Target ResolveProjectReferences:
2> ErrorFunction.cpp
2> FastMarching.cpp
5>Target InitializeBuildStatus:
5> Creating "x64\Debug\translations\translations.tlog\unsuccessfulbuild" because "AlwaysCreate" was specified.
2> FastMarchingForPropagation.cpp
2> GeometricalAnalysisTools.cpp
3>Target ClCompile:
3> mocs_compilation.cpp
3> ccBilateralFilter.cpp
3> ccFrameBufferObject.cpp
3> ccShader.cpp
5>Target CustomBuild:
5> Generating CloudCompare_es_AR.qm
2> KdTree.cpp
2> LocalModel.cpp
2> ManualSegmentationTools.cpp
2> MeshSamplingTools.cpp
5> Updating 'D:/CloudCompare/CCBUILD/qCC/translations/CloudCompare_es_AR.qm'...
5> Generated 2498 translation(s) (2497 finished and 1 unfinished)
5> Ignored 5 untranslated source text(s)
2> Neighbourhood.cpp
3>Target ResolvedLinkLib:
2> NormalDistribution.cpp
5> Generating CloudCompare_fr.qm
2> NormalizedProgress.cpp
3>Target Lib:
3> CC_FBO_LIB.vcxproj -> D:\CloudCompare\CCBUILD\libs\CCFbo\Debug\CC_FBO_LIBd.lib
5> Updating 'D:/CloudCompare/CCBUILD/qCC/translations/CloudCompare_fr.qm'...
5> Generated 498 translation(s) (386 finished and 112 unfinished)
5> Ignored 2193 untranslated source text(s)
2> PointProjectionTools.cpp
5> Generating CloudCompare_ja.qm
2> Polyline.cpp
2> ReferenceCloud.cpp
2> RegistrationTools.cpp
5> Updating 'D:/CloudCompare/CCBUILD/qCC/translations/CloudCompare_ja.qm'...
5> Generated 651 translation(s) (534 finished and 117 unfinished)
5> Ignored 2040 untranslated source text(s)
3>Target FinalizeBuildStatus:
3> Deleting file "CC_FBO_LIB.dir\Debug\CC_FBO_LIB.tlog\unsuccessfulbuild".
3> Touching "CC_FBO_LIB.dir\Debug\CC_FBO_LIB.tlog\CC_FBO_LIB.lastbuildstate".
3>
3>Build succeeded.
3> 0 Warning(s)
3> 0 Error(s)
3>
3>Time Elapsed 00:00:17.82
6>------ Rebuild All started: Project: translations_es, Configuration: Debug x64 ------
6>Build started 16.02.2020 16:25:24.
5> Generating CloudCompare_pt.qm
2> SaitoSquaredDistanceTransform.cpp
6>Target ResolveProjectReferences:
2> ScalarField.cpp
6>Target InitializeBuildStatus:
6> Creating "x64\Debug\translations_es\translations_es.tlog\unsuccessfulbuild" because "AlwaysCreate" was specified.
5> Updating 'D:/CloudCompare/CCBUILD/qCC/translations/CloudCompare_pt.qm'...
5> Generated 563 translation(s) (97 finished and 466 unfinished)
5> Ignored 2128 untranslated source text(s)
5> Generating CloudCompare_ru.qm
2> ScalarFieldTools.cpp
6>Target CustomBuild:
6> Generating Qt language file for es
5> Updating 'D:/CloudCompare/CCBUILD/qCC/translations/CloudCompare_ru.qm'...
5> Generated 2691 translation(s) (2691 finished and 0 unfinished)
2> SimpleMesh.cpp
5> Building Custom Rule D:/CloudCompare/CloudCompare/qCC/translations/CMakeLists.txt
2> StatisticalTestingTools.cpp
6> Building Custom Rule D:/CloudCompare/CloudCompare/qCC/translations/CMakeLists.txt
2> TrueKdTree.cpp
2> WeibullDistribution.cpp
6>Target FinalizeBuildStatus:
6> Deleting file "x64\Debug\translations_es\translations_es.tlog\unsuccessfulbuild".
5>Target FinalizeBuildStatus:
5> Deleting file "x64\Debug\translations\translations.tlog\unsuccessfulbuild".
6> Touching "x64\Debug\translations_es\translations_es.tlog\translations_es.lastbuildstate".
6>
6>Build succeeded.
6> 0 Warning(s)
6> 0 Error(s)
6>
6>Time Elapsed 00:00:04.84
7>------ Rebuild All started: Project: translations_fr, Configuration: Debug x64 ------
5> Touching "x64\Debug\translations\translations.tlog\translations.lastbuildstate".
5>
5>Build succeeded.
5> 0 Warning(s)
5> 0 Error(s)
5>
5>Time Elapsed 00:00:19.48
8>------ Rebuild All started: Project: translations_ja, Configuration: Debug x64 ------
7>Build started 16.02.2020 16:25:29.
7>Target ResolveProjectReferences:
4>Target ResolvedLinkLib:
7>Target InitializeBuildStatus:
7> Creating "x64\Debug\translations_fr\translations_fr.tlog\unsuccessfulbuild" because "AlwaysCreate" was specified.
7>Target CustomBuild:
7> Generating Qt language file for fr
7> Building Custom Rule D:/CloudCompare/CloudCompare/qCC/translations/CMakeLists.txt
7>Target FinalizeBuildStatus:
7> Deleting file "x64\Debug\translations_fr\translations_fr.tlog\unsuccessfulbuild".
7> Touching "x64\Debug\translations_fr\translations_fr.tlog\translations_fr.lastbuildstate".
7>
7>Build succeeded.
7> 0 Warning(s)
7> 0 Error(s)
7>
7>Time Elapsed 00:00:00.36
9>------ Rebuild All started: Project: translations_ru, Configuration: Debug x64 ------
9>Build started 16.02.2020 16:25:29.
9>Target ResolveProjectReferences:
4>Target Lib:
4> qcustomplot.vcxproj -> D:\CloudCompare\CCBUILD\libs\qcustomplot\Debug\qcustomplotd.lib
9>Target InitializeBuildStatus:
9> Creating "x64\Debug\translations_ru\translations_ru.tlog\unsuccessfulbuild" because "AlwaysCreate" was specified.
4>Target GetCopyToOutputDirectoryItems:
4>Target FinalizeBuildStatus:
4> Deleting file "qcustomplot.dir\Debug\qcustomplot.tlog\unsuccessfulbuild".
4> Touching "qcustomplot.dir\Debug\qcustomplot.tlog\qcustomplot.lastbuildstate".
4>
4>Build succeeded.
4> 0 Warning(s)
4> 0 Error(s)
4>
4>Time Elapsed 00:00:23.57
9>Target CustomBuild:
9> Generating Qt language file for ru
9> Building Custom Rule D:/CloudCompare/CloudCompare/qCC/translations/CMakeLists.txt
9>Target FinalizeBuildStatus:
9> Deleting file "x64\Debug\translations_ru\translations_ru.tlog\unsuccessfulbuild".
9> Touching "x64\Debug\translations_ru\translations_ru.tlog\translations_ru.lastbuildstate".
9>
9>Build succeeded.
9> 0 Warning(s)
9> 0 Error(s)
9>
9>Time Elapsed 00:00:00.37
8>Build started 16.02.2020 16:25:30.
8>Target ResolveProjectReferences:
8>Target InitializeBuildStatus:
8> Creating "x64\Debug\translations_ja\translations_ja.tlog\unsuccessfulbuild" because "AlwaysCreate" was specified.
8>Target CustomBuild:
8> Generating Qt language file for ja
8> Building Custom Rule D:/CloudCompare/CloudCompare/qCC/translations/CMakeLists.txt
8>Target FinalizeBuildStatus:
8> Deleting file "x64\Debug\translations_ja\translations_ja.tlog\unsuccessfulbuild".
8> Touching "x64\Debug\translations_ja\translations_ja.tlog\translations_ja.lastbuildstate".
8>
8>Build succeeded.
8> 0 Warning(s)
8> 0 Error(s)
8>
8>Time Elapsed 00:00:00.25
2>Target ResolvedLinkLib:
2>Target Link:
2> Creating library D:/CloudCompare/CCBUILD/CC/Debug/CC_CORE_LIBd.lib and object D:/CloudCompare/CCBUILD/CC/Debug/CC_CORE_LIBd.exp
2> CC_CORE_LIB.vcxproj -> D:\CloudCompare\CCBUILD\CC\Debug\CC_CORE_LIBd.dll
2>Target GetCopyToOutputDirectoryItems:
2>Target FinalizeBuildStatus:
2> Deleting file "CC_CORE_LIB.dir\Debug\CC_CORE_LIB.tlog\unsuccessfulbuild".
2> Touching "CC_CORE_LIB.dir\Debug\CC_CORE_LIB.tlog\CC_CORE_LIB.lastbuildstate".
2>
2>Build succeeded.
2> 0 Warning(s)
2> 0 Error(s)
2>
2>Time Elapsed 00:00:26.05
10>------ Rebuild All started: Project: QCC_DB_LIB, Configuration: Debug x64 ------
10>Build started 16.02.2020 16:25:32.
10>Target ResolveProjectReferences:
10>Target InitializeBuildStatus:
10> Creating "QCC_DB_LIB.dir\Debug\QCC_DB_LIB.tlog\unsuccessfulbuild" because "AlwaysCreate" was specified.
10>Target PreBuildEvent:
10> Automatic MOC for target QCC_DB_LIB
10>Target CustomBuild:
10> Building Custom Rule D:/CloudCompare/CloudCompare/libs/qCC_db/CMakeLists.txt
10>Target ClCompile:
10> mocs_compilation.cpp
10> cc2DLabel.cpp
10> cc2DViewportLabel.cpp
10> cc2DViewportObject.cpp
10> ccAdvancedTypes.cpp
10> ccBBox.cpp
10> ccBox.cpp
10> ccCameraSensor.cpp
10> ccClipBox.cpp
10> ccColorRampShader.cpp
10> ccColorScale.cpp
10> ccColorScalesManager.cpp
10> ccColorTypes.cpp
10> ccCone.cpp
10> ccCylinder.cpp
10> ccDepthBuffer.cpp
10> ccDish.cpp
10> ccDrawableObject.cpp
10> ccExternalFactory.cpp
10> ccExtru.cpp
10> ccFacet.cpp
10> ccFastMarchingForNormsDirection.cpp
10> ccGBLSensor.cpp
10> ccGenericGLDisplay.cpp
10> ccGenericMesh.cpp
10> ccGenericPointCloud.cpp
10> ccGenericPrimitive.cpp
10> ccGriddedTools.cpp
10> ccHObject.cpp
10> ccHObjectCaster.cpp
10> ccImage.cpp
10> ccIndexedTransformation.cpp
10> ccIndexedTransformationBuffer.cpp
10> ccKdTree.cpp
10> ccLog.cpp
10> ccMaterial.cpp
10> ccMaterialSet.cpp
10> ccMesh.cpp
10> ccMeshGroup.cpp
10> ccMinimumSpanningTreeForNormsDirection.cpp
10> ccNormalCompressor.cpp
10> ccNormalVectors.cpp
10> ccObject.cpp
10> ccOctree.cpp
10> ccOctreeProxy.cpp
10> ccOctreeSpinBox.cpp
10> ccPlanarEntityInterface.cpp
10> ccPlane.cpp
10> ccPointCloud.cpp
10> ccPointCloudInterpolator.cpp
10> ccPointCloudLOD.cpp
10> ccPolyline.cpp
10> ccProgressDialog.cpp
10> ccQuadric.cpp
10> ccRasterGrid.cpp
10> ccScalarField.cpp
10> ccSensor.cpp
10> ccShiftedObject.cpp
10> ccSphere.cpp
10> ccSubMesh.cpp
10> ccTorus.cpp
10> ccWaveform.cpp
10>Target ResolvedLinkLib:
10>Target Link:
10> Creating library D:/CloudCompare/CCBUILD/libs/qCC_db/Debug/QCC_DB_LIBd.lib and object D:/CloudCompare/CCBUILD/libs/qCC_db/Debug/QCC_DB_LIBd.exp
10> QCC_DB_LIB.vcxproj -> D:\CloudCompare\CCBUILD\libs\qCC_db\Debug\QCC_DB_LIBd.dll
10>Target GetCopyToOutputDirectoryItems:
10>Target FinalizeBuildStatus:
10> Deleting file "QCC_DB_LIB.dir\Debug\QCC_DB_LIB.tlog\unsuccessfulbuild".
10> Touching "QCC_DB_LIB.dir\Debug\QCC_DB_LIB.tlog\QCC_DB_LIB.lastbuildstate".
10>
10>Build succeeded.
10> 0 Warning(s)
10> 0 Error(s)
10>
10>Time Elapsed 00:01:24.01
11>------ Rebuild All started: Project: QCC_GL_LIB, Configuration: Debug x64 ------
12>------ Rebuild All started: Project: QCC_IO_LIB, Configuration: Debug x64 ------
11>Build started 16.02.2020 16:26:56.
11>Target ResolveProjectReferences:
12>Build started 16.02.2020 16:26:56.
12>Target ResolveProjectReferences:
12>Target InitializeBuildStatus:
12> Creating "QCC_IO_LIB.dir\Debug\QCC_IO_LIB.tlog\unsuccessfulbuild" because "AlwaysCreate" was specified.
12>Target PreBuildEvent:
12> Automatic MOC for target QCC_IO_LIB
11>Target InitializeBuildStatus:
11> Creating "QCC_GL_LIB.dir\Debug\QCC_GL_LIB.tlog\unsuccessfulbuild" because "AlwaysCreate" was specified.
11>Target PreBuildEvent:
11> Automatic MOC for target QCC_GL_LIB
11>Target CustomBuild:
11> Building Custom Rule D:/CloudCompare/CloudCompare/libs/qCC_glWindow/CMakeLists.txt
12>Target CustomBuild:
12> Generating ui_globalShiftAndScaleAboutDlg.h
12> Generating ui_globalShiftAndScaleDlg.h
12> Generating ui_importDBFFieldDlg.h
12> Generating ui_openAsciiFileDlg.h
11>Target ClCompile:
11> mocs_compilation.cpp
11> ccGLUtils.cpp
11> ccGLWindow.cpp
11> ccGuiParameters.cpp
12> Generating ui_openPlyFileDlg.h
12> Generating ui_saveAsciiFileDlg.h
12> Generating ui_saveSHPFileDlg.h
12> Building Custom Rule D:/CloudCompare/CloudCompare/libs/qCC_io/CMakeLists.txt
12>Target ClCompile:
12> mocs_compilation.cpp
12> AsciiFilter.cpp
12> AsciiOpenDlg.cpp
12> AsciiSaveDlg.cpp
11> ccRenderingTools.cpp
12> BinFilter.cpp
12> DepthMapFileFilter.cpp
12> DxfFilter.cpp
12> FileIO.cpp
11>Target ResolvedLinkLib:
11>Target Lib:
11> QCC_GL_LIB.vcxproj -> D:\CloudCompare\CCBUILD\libs\qCC_glWindow\Debug\QCC_GL_LIBd.lib
11>Target GetCopyToOutputDirectoryItems:
11>Target FinalizeBuildStatus:
11> Deleting file "QCC_GL_LIB.dir\Debug\QCC_GL_LIB.tlog\unsuccessfulbuild".
11> Touching "QCC_GL_LIB.dir\Debug\QCC_GL_LIB.tlog\QCC_GL_LIB.lastbuildstate".
11>
11>Build succeeded.
11> 0 Warning(s)
11> 0 Error(s)
11>
11>Time Elapsed 00:00:15.65
12> FileIOFilter.cpp
12> ImageFileFilter.cpp
12> PlyFilter.cpp
12> PlyOpenDlg.cpp
12> RasterGridFilter.cpp
12> ShpDBFFields.cpp
12> ShpFilter.cpp
12> ccGlobalShiftManager.cpp
12> ccShiftAndScaleCloudDlg.cpp
12> rply.c
12>Target ResolvedLinkLib:
12>Target Link:
12> Creating library D:/CloudCompare/CCBUILD/libs/qCC_io/Debug/QCC_IO_LIBd.lib and object D:/CloudCompare/CCBUILD/libs/qCC_io/Debug/QCC_IO_LIBd.exp
12> QCC_IO_LIB.vcxproj -> D:\CloudCompare\CCBUILD\libs\qCC_io\Debug\QCC_IO_LIBd.dll
12>Target GetCopyToOutputDirectoryItems:
12>Target FinalizeBuildStatus:
12> Deleting file "QCC_IO_LIB.dir\Debug\QCC_IO_LIB.tlog\unsuccessfulbuild".
12> Touching "QCC_IO_LIB.dir\Debug\QCC_IO_LIB.tlog\QCC_IO_LIB.lastbuildstate".
12>
12>Build succeeded.
12> 0 Warning(s)
12> 0 Error(s)
12>
12>Time Elapsed 00:00:30.13
13>------ Rebuild All started: Project: CloudCompare, Configuration: Debug x64 ------
14>------ Rebuild All started: Project: ExampleIOPlugin, Configuration: Debug x64 ------
15>------ Rebuild All started: Project: QCORE_IO_PLUGIN, Configuration: Debug x64 ------
16>------ Rebuild All started: Project: ccViewer, Configuration: Debug x64 ------
14>Build started 16.02.2020 16:27:26.
15>Build started 16.02.2020 16:27:26.
15>Target ResolveProjectReferences:
16>Build started 16.02.2020 16:27:26.
13>Build started 16.02.2020 16:27:26.
16>Target ResolveProjectReferences:
16> Target GetNativeManifest:
16>Target InitializeBuildStatus:
16> Creating "ccViewer.dir\Debug\ccViewer.tlog\unsuccessfulbuild" because "AlwaysCreate" was specified.
16>Target PreBuildEvent:
16> Automatic MOC for target ccViewer
14>Target ResolveProjectReferences:
14>Target InitializeBuildStatus:
14> Creating "ExampleIOPlugin.dir\Debug\ExampleIOPlugin.tlog\unsuccessfulbuild" because "AlwaysCreate" was specified.
14>Target PreBuildEvent:
14> Automatic MOC for target ExampleIOPlugin
15>Target InitializeBuildStatus:
15> Creating "QCORE_IO_PLUGIN.dir\Debug\QCORE_IO_PLUGIN.tlog\unsuccessfulbuild" because "AlwaysCreate" was specified.
15>Target PreBuildEvent:
15> Automatic MOC for target QCORE_IO_PLUGIN
13>Target ResolveProjectReferences:
14>Target CustomBuild:
14> Generating qrc_ExampleIOPlugin.cpp
15>Target CustomBuild:
15> Generating ui_saveMascaretFileDlg.h
16>Target CustomBuild:
16> Generating ui_ccviewer.h
14> Building Custom Rule D:/CloudCompare/CloudCompare/plugins/example/ExampleIOPlugin/CMakeLists.txt
15> Generating qrc_qCoreIO.cpp
16> Generating ui_ccviewerAbout.h
15> Building Custom Rule D:/CloudCompare/CloudCompare/plugins/core/IO/qCoreIO/CMakeLists.txt
16> Generating ui_cameraParamDlg.h
16> Generating ui_displayOptionsDlg.h
16> Generating ui_pickOneElementDlg.h
16> Generating ui_stereoModeDlg.h
16> Generating qrc_icones.cpp
15>Target ClCompile:
15> mocs_compilation.cpp
14>Target ClCompile:
14> mocs_compilation.cpp
15> qCoreIO.cpp
15> ccDefaultPluginInterface.cpp
15> HeightProfileFilter.cpp
14> ExampleIOPlugin.cpp
14> ccDefaultPluginInterface.cpp
14> FooFilter.cpp
13> Target GetTargetPath:
13>Target InitializeBuildStatus:
13> Creating "CloudCompare.dir\Debug\CloudCompare.tlog\unsuccessfulbuild" because "AlwaysCreate" was specified.
13>Target PreBuildEvent:
13> Automatic MOC for target CloudCompare
16> Building Custom Rule D:/CloudCompare/CloudCompare/ccViewer/CMakeLists.txt
14> qrc_ExampleIOPlugin.cpp
15> MAFilter.cpp
15> MascaretFilter.cpp
15> ObjFilter.cpp
15> OFFFilter.cpp
16>Target ClCompile:
16> mocs_compilation.cpp
16> ccViewerApplication.cpp
16> ccviewer.cpp
16> main.cpp
14>Target ResolvedLinkLib:
14> Target GetResolvedLinkLibs:
13>Target CustomBuild:
13> Generating ui_aboutDlg.h
13> Generating ui_adjustZoomDlg.h
14>Target Link:
14> Creating library D:/CloudCompare/CCBUILD/plugins/example/ExampleIOPlugin/Debug/ExampleIOPlugind.lib and object D:/CloudCompare/CCBUILD/plugins/example/ExampleIOPlugin/Debug/ExampleIOPlugind.exp
13> Generating ui_alignDlg.h
16> ccApplicationBase.cpp
14> ExampleIOPlugin.vcxproj -> D:\CloudCompare\CCBUILD\plugins\example\ExampleIOPlugin\Debug\ExampleIOPlugind.dll
15> PTXFilter.cpp
13> Generating ui_applyTransformationDlg.h
14>Target GetCopyToOutputDirectoryItems:
15> SimpleBinFilter.cpp
14>Target FinalizeBuildStatus:
14> Deleting file "ExampleIOPlugin.dir\Debug\ExampleIOPlugin.tlog\unsuccessfulbuild".
14> Touching "ExampleIOPlugin.dir\Debug\ExampleIOPlugin.tlog\ExampleIOPlugin.lastbuildstate".
14>
14>Build succeeded.
14> 0 Warning(s)
14> 0 Error(s)
14>
14>Time Elapsed 00:00:18.99
15> STLFilter.cpp
15> VTKFilter.cpp
16> ccCameraParamEditDlg.cpp
13> Generating ui_askOneDoubleValueDlg.h
16> ccDisplayOptionsDlg.cpp
16> ccOptions.cpp
13> Generating ui_askOneIntValueDlg.h
13> Generating ui_askOneStringDlg.h
16> ccOverlayDialog.cpp
15> PDMSFilter.cpp
16> ccPickingHub.cpp
16> ccPickOneElementDlg.cpp
13> Generating ui_askThreeDoubleValuesDlg.h
15> PdmsParser.cpp
15> PdmsTools.cpp
13> Generating ui_askTwoDoubleValuesDlg.h
15> qrc_qCoreIO.cpp
13> Generating ui_boundingBoxEditorDlg.h
16> ccPluginManager.cpp
16> ccStereoModeDlg.cpp
13> Generating ui_camSensorProjectDlg.h
13> Generating ui_clippingBoxDlg.h
13> Generating ui_clippingBoxRepeatDlg.h
13> Generating ui_colorGradientDlg.h
13> Generating ui_colorLevelsDlg.h
13> Generating ui_colorScaleEditorDlg.h
15>Target ResolvedLinkLib:
13> Generating ui_commandLineDlg.h
13> Generating ui_comparisonDlg.h
13> Generating ui_computeOctreeDlg.h
13> Generating ui_contourExtractorDlg.h
13> Generating ui_dipDirTransformationDlg.h
13> Generating ui_distanceMapDlg.h
13> Generating ui_entitySelectionDlg.h
13> Generating ui_exportCoordToSFDlg.h
13> Generating ui_filterByValueDlg.h
13> Generating ui_gblSensorProjectDlg.h
16> ccTranslationManager.cpp
16> qrc_icones.cpp
13> Generating ui_geomFeaturesDlg.h
13> Generating ui_globalShiftSettingsDlg.h
13> Generating ui_graphicalSegmentationDlg.h
13> Generating ui_graphicalTransformationDlg.h
13> Generating ui_heightGridGenerationDlg.h
13> Generating ui_histogramDlg.h
13> Generating ui_interpolationDlg.h
13> Generating ui_itemSelectionDlg.h
13> Generating ui_labelingDlg.h
13> Generating ui_mainWindow.h
13> Generating ui_matchScalesDlg.h
13> Generating ui_matrixDisplayDlg.h
13> Generating ui_noiseFilterDlg.h
13> Generating ui_normalComputationDlg.h
13> Generating ui_orthoSectionGenerationDlg.h
13> Generating ui_planeEditDlg.h
13> Generating ui_pointListPickingDlg.h
15>Target Link:
15> Creating library D:/CloudCompare/CCBUILD/plugins/core/IO/qCoreIO/Debug/QCORE_IO_PLUGINd.lib and object D:/CloudCompare/CCBUILD/plugins/core/IO/qCoreIO/Debug/QCORE_IO_PLUGINd.exp
13> Generating ui_pointPairRegistrationDlg.h
15> QCORE_IO_PLUGIN.vcxproj -> D:\CloudCompare\CCBUILD\plugins\core\IO\qCoreIO\Debug\QCORE_IO_PLUGINd.dll
15>Target GetCopyToOutputDirectoryItems:
15>Target FinalizeBuildStatus:
15> Deleting file "QCORE_IO_PLUGIN.dir\Debug\QCORE_IO_PLUGIN.tlog\unsuccessfulbuild".
15> Touching "QCORE_IO_PLUGIN.dir\Debug\QCORE_IO_PLUGIN.tlog\QCORE_IO_PLUGIN.lastbuildstate".
15>
15>Build succeeded.
15> 0 Warning(s)
15> 0 Error(s)
15>
15>Time Elapsed 00:00:41.09
13> Generating ui_pointPropertiesDlg.h
13> Generating ui_primitiveDistanceDlg.h
13> Generating ui_primitiveFactoryDlg.h
13> Generating ui_ptsSamplingDlg.h
13> Generating ui_rasterExportOptionsDlg.h
13> Generating ui_rasterizeDlg.h
13> Generating ui_registrationDlg.h
13> Generating ui_renderToFileDialog.h
16>Target ResolvedLinkLib:
13> Generating ui_roleChoiceDlg.h
13> Generating ui_scalarFieldFromColorDlg.h
13> Generating ui_scaleDlg.h
13> Generating ui_sectionExtractionDlg.h
13> Generating ui_sectionExtractionSubDlg.h
13> Generating ui_selectChildrenDlg.h
13> Generating ui_sensorComputeDistancesDlg.h
13> Generating ui_sensorComputeScatteringAnglesDlg.h
13> Generating ui_sfArithmeticsDlg.h
13> Generating ui_sfEditDlg.h
13> Generating ui_sorFilterDlg.h
13> Generating ui_statisticalTestDlg.h
13> Generating ui_subsamplingDlg.h
13> Generating ui_tracePolylineDlg.h
13> Generating ui_unrollDlg.h
13> Generating ui_volumeCalcDlg.h
13> Generating ui_waveDlg.h
13> Generating ui_cameraParamDlg.h
13> Generating ui_displayOptionsDlg.h
13> Generating ui_pickOneElementDlg.h
16>Target Link:
16> Qt5OpenGLExtensionsd.lib(qopenglextensions.obj) : warning LNK4099: PDB 'Qt5OpenGLExtensionsd.pdb' was not found with 'Qt5OpenGLExtensionsd.lib(qopenglextensions.obj)' or at 'D:\CloudCompare\CCBUILD\ccViewer\Debug\Qt5OpenGLExtensionsd.pdb'; linking object as if no debug info
13> Generating ui_stereoModeDlg.h
13> Generating ui_ccPluginInfoDlg.h
13> Generating qrc_icones.cpp
13> Generating qrc_pluginManager.cpp
13> Building Custom Rule D:/CloudCompare/CloudCompare/qCC/CMakeLists.txt
16> ccViewer.vcxproj -> D:\CloudCompare\CCBUILD\ccViewer\Debug\ccViewer.exe
16>Done building target "Link" in project "ccViewer.vcxproj".
16>Target GetCopyToOutputDirectoryItems:
16>Target FinalizeBuildStatus:
16> Deleting file "ccViewer.dir\Debug\ccViewer.tlog\unsuccessfulbuild".
16> Touching "ccViewer.dir\Debug\ccViewer.tlog\ccViewer.lastbuildstate".
16>
16>Done building project "ccViewer.vcxproj".
16>
16>Build succeeded.
16>
16>Qt5OpenGLExtensionsd.lib(qopenglextensions.obj) : warning LNK4099: PDB 'Qt5OpenGLExtensionsd.pdb' was not found with 'Qt5OpenGLExtensionsd.lib(qopenglextensions.obj)' or at 'D:\CloudCompare\CCBUILD\ccViewer\Debug\Qt5OpenGLExtensionsd.pdb'; linking object as if no debug info
16> 1 Warning(s)
16> 0 Error(s)
16>
16>Time Elapsed 00:00:43.73
13>Target ClCompile:
13> mocs_compilation.cpp
13> cc2.5DimEditor.cpp
13> ccAboutDialog.cpp
13> ccAdjustZoomDlg.cpp
13> ccAlignDlg.cpp
13> ccApplication.cpp
13> ccApplyTransformationDlg.cpp
13> ccAskThreeDoubleValuesDlg.cpp
13> ccAskTwoDoubleValuesDlg.cpp
13> ccBoundingBoxEditorDlg.cpp
13> ccCamSensorProjectionDlg.cpp
13> ccClippingBoxRepeatDlg.cpp
13> ccClippingBoxTool.cpp
13> ccColorGradientDlg.cpp
13> ccColorLevelsDlg.cpp
13> ccColorScaleEditorDlg.cpp
13> ccColorScaleEditorWidget.cpp
13> ccColorScaleSelector.cpp
13> ccCommandCrossSection.cpp
13> ccCommandLineCommands.cpp
13> ccCommandLineParser.cpp
13> ccCommandRaster.cpp
13> ccComparisonDlg.cpp
13> ccComputeOctreeDlg.cpp
13> ccConsole.cpp
13> ccContourExtractor.cpp
13> ccContourExtractorDlg.cpp
13> ccCropTool.cpp
13> ccEntityAction.cpp
13> ccEntitySelectionDlg.cpp
13> ccExportCoordToSFDlg.cpp
13> ccFilterByValueDlg.cpp
13> ccGBLSensorProjectionDlg.cpp
13> ccGeomFeaturesDlg.cpp
13> ccGraphicalSegmentationTool.cpp
13> ccGraphicalTransformationTool.cpp
13> ccHistogramWindow.cpp
13> ccInnerRect2DFinder.cpp
13> ccInterpolationDlg.cpp
13> ccItemSelectionDlg.cpp
13> ccLabelingDlg.cpp
13> ccLibAlgorithms.cpp
13> ccMatchScalesDlg.cpp
13> ccNoiseFilterDlg.cpp
13> ccNormalComputationDlg.cpp
13> ccOrderChoiceDlg.cpp
13> ccOrthoSectionGenerationDlg.cpp
13> ccPlaneEditDlg.cpp
13> ccPointListPickingDlg.cpp
13> ccPointPairRegistrationDlg.cpp
13> ccPointPickingGenericInterface.cpp
13> ccPointPropertiesDlg.cpp
13> ccPrimitiveDistanceDlg.cpp
13> ccPrimitiveFactoryDlg.cpp
13> ccPtsSamplingDlg.cpp
13> ccRasterizeTool.cpp
13> ccRecentFiles.cpp
13> ccRegistrationDlg.cpp
13> ccRegistrationTools.cpp
13> ccRenderToFileDlg.cpp
13> ccSORFilterDlg.cpp
13> ccScalarFieldArithmeticsDlg.cpp
13> ccScalarFieldFromColorDlg.cpp
13> ccScaleDlg.cpp
13> ccSectionExtractionSubDlg.cpp
13> ccSectionExtractionTool.cpp
13> ccSelectChildrenDlg.cpp
13> ccSensorComputeDistancesDlg.cpp
13> ccSensorComputeScatteringAnglesDlg.cpp
13> ccStatisticalTestDlg.cpp
13> ccSubsamplingDlg.cpp
13> ccTracePolylineTool.cpp
13> ccUnrollDlg.cpp
13> ccUtils.cpp
13> ccVolumeCalcTool.cpp
13> ccWaveformDialog.cpp
13> main.cpp
13> mainwindow.cpp
13> ccApplicationBase.cpp
13> ccCameraParamEditDlg.cpp
13> ccDisplayOptionsDlg.cpp
13> ccOptions.cpp
13> ccOverlayDialog.cpp
13> ccPickingHub.cpp
13> ccPickOneElementDlg.cpp
13> ccPluginManager.cpp
13> ccStereoModeDlg.cpp
13> ccTranslationManager.cpp
13> ccDBRoot.cpp
13> ccPropertiesTreeDelegate.cpp
13> matrixDisplayDlg.cpp
13> sfEditDlg.cpp
13> ccPluginInfoDlg.cpp
13> ccPluginUIManager.cpp
13> qrc_icones.cpp
13> qrc_pluginManager.cpp
13>Target ResolvedLinkLib:
13>Target Link:
13> Qt5OpenGLExtensionsd.lib(qopenglextensions.obj) : warning LNK4099: PDB 'Qt5OpenGLExtensionsd.pdb' was not found with 'Qt5OpenGLExtensionsd.lib(qopenglextensions.obj)' or at 'D:\CloudCompare\CCBUILD\qCC\Debug\Qt5OpenGLExtensionsd.pdb'; linking object as if no debug info
13> CloudCompare.vcxproj -> D:\CloudCompare\CCBUILD\qCC\Debug\CloudCompare.exe
13>Done building target "Link" in project "CloudCompare.vcxproj".
13>Target GetCopyToOutputDirectoryItems:
13>Target FinalizeBuildStatus:
13> Deleting file "CloudCompare.dir\Debug\CloudCompare.tlog\unsuccessfulbuild".
13> Touching "CloudCompare.dir\Debug\CloudCompare.tlog\CloudCompare.lastbuildstate".
13>
13>Done building project "CloudCompare.vcxproj".
13>
13>Build succeeded.
13>
13>Qt5OpenGLExtensionsd.lib(qopenglextensions.obj) : warning LNK4099: PDB 'Qt5OpenGLExtensionsd.pdb' was not found with 'Qt5OpenGLExtensionsd.lib(qopenglextensions.obj)' or at 'D:\CloudCompare\CCBUILD\qCC\Debug\Qt5OpenGLExtensionsd.pdb'; linking object as if no debug info
13> 1 Warning(s)
13> 0 Error(s)
13>
13>Time Elapsed 00:02:54.03
17>------ Rebuild All started: Project: ALL_BUILD, Configuration: Debug x64 ------
17>Build started 16.02.2020 16:30:20.
17>Target ResolveProjectReferences:
17>Target InitializeBuildStatus:
17> Creating "x64\Debug\ALL_BUILD\ALL_BUILD.tlog\unsuccessfulbuild" because "AlwaysCreate" was specified.
17>Target CustomBuild:
17> Building Custom Rule D:/CloudCompare/CloudCompare/CMakeLists.txt
17>Target FinalizeBuildStatus:
17> Deleting file "x64\Debug\ALL_BUILD\ALL_BUILD.tlog\unsuccessfulbuild".
17> Touching "x64\Debug\ALL_BUILD\ALL_BUILD.tlog\ALL_BUILD.lastbuildstate".
17>
17>Build succeeded.
17> 0 Warning(s)
17> 0 Error(s)
17>
17>Time Elapsed 00:00:00.27
18>------ Skipped Rebuild All: Project: INSTALL, Configuration: Debug x64 ------
18>Project not selected to build for this solution configuration
========== Rebuild All: 17 succeeded, 0 failed, 1 skipped ==========
- error_ad.PNG (90.14 KiB) Viewed 8365 times
Have you compiled the INSTALL project? And set the right install destination directory in CMake ? (see https://github.com/CloudCompare/CloudCo ... r/BUILD.md).
Also check the section about setting Visual Studio correctly (and the link to this message: http://www.danielgm.net/cc/forum/viewtopic.php?t=992)
