LAS files
murraysyaman
LAS files
Post by murraysyaman »
Hi, I'm a very new user to cloud compare and i cant import LAS files into the programme. When i try to open the data is doesnt even recognise the data as a file to import and the folder appears empty.
Any help would be much appreciated,
thanks
Re: LAS files
Do you get an error message maybe? (or a warning one in the Console?)
If you are using the Windows version, you can also try to load your LAS file with the non-default filter ("LAS 1.3 or 1.4"). You'll have to load the data via the 'File > Load' dialog and change the default filter).
