surface area calculation
doaa
Re: surface area calculation
Post by doaa »
many thank daniel
In a previous question on calculating the surface area of the segmented point cloud. you answered as shown
daniel wrote: Sun Aug 12, 2018 12:44 pm You can try to segment the part with the scissors tool and then use the 'Tools > Fit > Facet' tool. It will fit a 'facet' element to the cloud, from which you can read the surface in its properties.
Oh, a "facet"' is a tesselated polygon that fits the cloud contours (this only works for 2.5D clouds). Then it's equivalent to a mesh, and the surface is simply the sum of the triangles areas.
doaa
Post by doaa »
Many thanks!
Your help is really appreciated!
