How to Tick (for Visibility) all Point Clouds (e.g. Sub-groups)?
imnn
Post by imnn »
Hi Daniel, I am wondering if there is a way to tick all of the point clouds together?
I know that I can select them all and by hitting 'D' or 'Edit>Toggle (recursive)> Visibility' I can visible/invisible point clouds.
However, I am not sure how I can actually tick them all together.
Could you please help me with that?
Many thanks,
Re: How to Tick (for Visibility) all Point Clouds (e.g. Sub-groups)?
Have you tried the 'Select children by type or name' option when you left click on the parent group entry in the DB tree?
Select all the clouds for instance. Then once selected, you can use the 'a' shortcut to toggle them on/off.
imnn
Post by imnn »
Thank you for your response. I tried that and it works for visibility if the point clouds already ticked.
My question was if there is a way to actual tick the point cloud. Please have a look at the Image below.
Many thanks,
Screenshot from 2019-02-26 10-44-00.png (227.47 KiB) Viewed 5090 times
Yes use the 'a' shortcut.
imnn
Post by imnn »
That works! Thank you.
