Proper way to specify filename in command line mode and how to close after?
DarknessRain
Post by DarknessRain »
I'm using this line
-O E:\Scans\FARO_Scan_002.fls -C_EXPORT_FMT ASC -EXT xyz -SAVE_CLOUDS FILE test.xyz
In order to try to convert a faro scan into an XYZ file. I keep getting this popup that says "Error Command expected (commands start with the '-'). Found 'FILE'"
I get the xyz file but it is just named "FARO_Scan_002_2018-05-08_08h28_22_187.xyz".
Also, is there a way to not have the little CC box open and wait for me to press 'ok' or automatically close it when finished?
Re: Proper way to specify filename in command line mode and how to close after?
Are you using the latest 2.10.alpha version? Because prior versions don't support the 'FILE' option...
