Converting lidar data to CloudCompare
UborNad
Post by UborNad »
Hello.
I use such a Lidar (Long range laser 3d scanner) to capture terrain geometry. How can I convert it to import to CloudCompare?
Re: Converting lidar data to CloudCompare
CloudCompare supports many different cloud and mesh formats so you should find one that works: http://www.cloudcompare.org/doc/wiki/in ... e=FILE_I/O
Most probably you should have PLY that will work for both.
