gonzalotap
Posts: 11 Joined: Sun Apr 22, 2012 8:46 am
Post
by gonzalotap » Mon Oct 01, 2012 3:15 pm
Why when you build a height grid the empty cells fill with a fixed value. the colour is purple.
There is a option to choose thisvalue but don´t work.
and it´s posible to choose the scalar field to fill the cells to the grid.
Best regards
Posts: 8244 Joined: Wed Oct 13, 2010 7:34 am
Post
by daniel » Wed Oct 03, 2012 7:36 am
Indeed the dialog is misleading here as it suggests that the "replacement value" option is available for images (while only the 'purple' transparent pixels are working right now). I'll try to fix this (either the dialog or I'll make the replacement value work also for images if you think it's a good idea?).
I'll look at these points for the next version.
gonzalotap
Post
by gonzalotap » Thu Nov 15, 2012 2:42 pm
Hi Daniel, in the new version still can not replace the value of empty cells?
or I'm doing wrong.
Best regards
Post
by daniel » Thu Nov 22, 2012 8:18 pm
I'll check that before the next release!
Post
by daniel » Thu Nov 29, 2012 2:45 pm
Ok, the last github trunk version is fixed/updated!
It will be available in the next release (before Christmas ;).
