Hi.
I'm on an ArchLinux computer and I updated my distro this morning (including Qt I guess).
I'm not able to load any file in CloudCompare anymore.
Don't know if it's related but neither a brand new clone nor my development version can now load files.
PS: I'm using regular ASCII files at the moment.
[Load] Can't guess file format: unhandled file extension 'XXX'
Re: [Load] Can't guess file format: unhandled file extension 'XXX'
Hi Pablo,
Many problems have occurred with ArchLinux recently...
Is it happening when dropping a file on the 3D view, or even when you use the loading dialog and specify a specific file filter?
Can you maybe run CC in debug mode and trace into "FileIOFilter::LoadFromFile"?
Same behavior for both the drag-and-drop and the QDialog window.daniel wrote:Hi Pablo,
Thanks for the hint, I'll give a look at FileIOFilter::LoadFromFile and come back.
Can't find what's wrong for now.
It works fine with a fresh clone using an up-to-date KUbuntu.
EDIT : the main difference here is that there are format filters on the *buntu distros and they're not here anymore using the ArchLinux. As far as my understanding of the process goes, you rely on the file extension to select a loading algorithm. But without any enxtension hint, CC just gives up on this selection step.
Interesting... The default file 'filters' are loaded at startup time (see main.cpp, line 229):
The InitInternalFilters method simply creates the I/O filters (ASCII, BIN, LAS, etc.) and registers them in a singleton container.
Maybe this singleton is not correctly accessed by the main application (as it's created in the QCC_IO_LIB library) but it shouldn't be an issue as the QCC_IO_LIB is statically linked...
FileIOFilter::InitInternalFilters(); //load all known I/O filters (plugins will come later!)
All right, here is the solution I found :
Here, everything works as expected.
But when in need of the Debug version :
And here, CC does not have the filters and does not allow me to open files.
Next :
Then, CC works as expected.
In the end it's just that the install process does not replace the required libraries when switching the CMAKE_BUILD_TYPE field.
So, nothing Qt related in this issue.
EDIT :
I tried to build+install in Release mode, start CC, build+install in Debug mode and start CC on a *buntu and got no issue.
So it could come from CMake on Arch or anything else in the universe.
Conclusion for Arch users : manually clear the libs while switching the CMAKE_BUILD_TYPE solve this issue.
cd path/to/cc
mkdir build
cd build
cmake .. -DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX=~/.local
make install
cmake .. -DCMAKE_BUILD_TYPE=Debug
make install
Next :
rm -rf ~/.local/lib/everythingLinkedToCC
make install
EDIT :
I don't know how it works on Linux: does the libraries have the same name in debug and release modes? Are they output in the same folder?
On Windows (with Visual Studio or code::blocks) the release and debug configurations are different, and generally the library names also. Therefore we don't have this kind of issue.
Hi Daniel.
Debug and Release libs both go in the same directory.
The only difference is the 'd' at the end of the file name in debug mode.
As a short term solution I use this command :
It removes every previously installed files (listed in the install_manifest.txt file which is CMake generated) on my system before reinstalling the updated ones.
It's equivalent to some kind of
[ ! -f install_manifest.txt ] || xargs rm < install_manifest.txtIt's equivalent to some kind of
make unsintall
