Level alternative method
I'm a new user of CC (discovered it a few days ago), and I'm using it for trying to compare some 3D prints to their stl counterparts. I'm also using it align the face of 3D to a plane. On the wiki page for the Level tool, it mentions an Alternative/more general method. I don't really understand the steps for this method. The file history mentions a post by a user but I can't seem to find the related forum post. Could anyone help with the steps for this general method.
Re: Level alternative method
I guess the more general approach is the Point-pair based alignment tool? https://www.cloudcompare.org/doc/wiki/index.php/Align
Align would work if I have the STL files to compare to. What about any scan that I just want to align a face to the xy plane?
Oh, the Level tool is the way to go. Not sure what other solution there is?
https://www.cloudcompare.org/doc/wiki/i ... ral_method This is on the Level wiki page.
Yes, but that's only if you want to align the mesh with something else than the XY plane.
This additional section of wiki aims at aligning several planes so that they become vertical, leading to the horizontal plane (missing in this cloud) to become horizontal. It will be hard to describe it in a more detailed way, apart maybe that you need the 'Scissors' tool (Edit > Segment) to single out the points that are part of the vertical planes.
