Looks like this.
Cloud Point showing up as a straight line
Re: Cloud Point showing up as a straight line
- 1.png (38.99 KiB) Viewed 1428 times
The bounding-box (and more generally the entity properties) doesn't appear in this capture...
Oops sorry, here you are. Thanks.
- Capture.PNG (145.08 KiB) Viewed 1364 times
Yes, so you can see that the bounding box along X and Y is super small (<0.02) and super large along Z (> 420).
This is once again typical from a geographical coordinate system. You can try to rescale X and Y with the 'Edit > Multiply / scale' tool (by using a factor of 100 for instance for X and Y only). This should help you see how the cloud looks like.
But I think you should better convert the coordinates to a Cartesian coordinate system prior to importing it in CC.
Thank you!!! I think changing the coordinates did the trick.daniel wrote: ↑Mon May 20, 2024 11:26 am Yes, so you can see that the bounding box along X and Y is super small (<0.02) and super large along Z (> 420).
